Matamp volume reduction
I have a Green GT120 which is too bloody loud. Anyone got any ideas of how to reduce the output? I have already fried a Marshall power brake. The guy who builds Orange amps in Denmark St reckons he could customize it to put a Master volume on it. I have also heard that you can remove the output valves to reduce the overall volume. I noticed some members of this forum who have posted pictures have two valves removed from the chassis - I was wondering if they were the afforementioned output valves?
Go for the master IMHO. You can pull two power tubes but in reality it will make an amp that's too loud into an amp that's...... still too loud. It's really amazing how little difference you hear in volume when you pull two tubes. Basically, you only get 1 db in volume reduction for halving the power. I had two Marshall Superleads that I had half-power-modded and it didn't change the volume at all...
I really like the way Orange did their master and I'm sure that they would do an excellent master mod for you. It will really make the amp more versatile and keep you happy.
The power brake is rated at 100 watts, isn't it? I'm surprised that you fried it since it ought to be able to handle a 4 EL34 amp. I use a Marshall SE100 speaker emulator with my 140 head and have had no problems. It's discontinued though.... Billy
Users browsing this forum: No registered users and 230 guests
