AD30TC Whistle
anyone come across a high pitched whistling noise coming from their Orange. I love my AD30TC but recently I have noticed this whistling on channel 2 (this was probably due to crashing my car with the Orange in the boot!).
Does anyone know how to get rid of this? does it require a service or a valve change??
Rob
www.thebox2.com
www.thebox2.com
Just a stupid question:
Do you have some effect pedals running in front of your amp?
I have the same behaviour, but only with one of my pedals in front of it.
In my case it is either the power supply of the pedal or the pedal itself. I haven't checked it yet.
But i think you have tested it anyway...
Please keep me informed with your latest informations. I'm interested in the reason of your problems.
Dude
Dude
I was once told that on 'very rare' occasions these high pitch noises come from problems with the attachment os the Grill Cloth. When you hear the high pitch try gently holding your hand on various parts of the grill and see if it dissapears. If it does you should probably contact Orange to see what the best solution would be.
Tour Manager - Guitar Technician
Dude, I do use effects in front but it still doing it direct from the guitar, so I can rule out that possible fault.
The sound is a really high pitched whistle. If I turn the amp onto standby, then on again, it goes. During a 4 hour practice session, it usually does it anything up to 4 or 5 times. Occasionally, it won't do it all night!?
Rob
www.thebox2.com
www.thebox2.com
It does it with other guitars, I assume, and you've tried other guitar cords?
Sounds like a bad preamp tube to me. Get a pencil (or any other non-conducting type of thing) or a chopstick and tap the preamp tubes. They're the 12AX7's not the EL84's. Take the metal shields off first before you turn on the amp (otherwise they'll be hot). Turn the amp on, tap and see if it comes and goes. If that's it, just replace the preamp tube with a good quality tube. Billy
Edited by - bclaire on 02 Dec 2003 04:51:54
will I be damaging the amp by using it if one of the valves is faulty? (assuming it is that)
Rob
www.thebox2.com
www.thebox2.com
i noticed the other day at rehearsal that it doesn't do it when the amp is cold.
it tends to happen when you can feel the heat from the grill on the top.
it was quite warm because i was pushing it quite hard on full gain but with the master only at about 11 o clock. it seemed to be doing it a lot towards the end of the session as the amp started to get quite warm.
Rob
www.thebox2.com
www.thebox2.com
how do i find out for sure which one it is?
i don't wanna have to buy a whole set of 4.
which preamp valves do you recommend?
Rob
www.thebox2.com
www.thebox2.com
There are a lot of good preamp tubes out there. See what is available in your area. Most likely, it's only the first tube for one of the channels. Replace that and I suspect your problem will go away.
Billy
Billy
Listen to Billy...time for new pre-tubes. You crashed your car with the amp in the boot, I would've replaced the tubes just out of principle.
Billy...when your 1st pre-tube goes microphonic, you can just switch it with one of the other ones. That should save you from buying a new one.
Users browsing this forum: No registered users and 93 guests
