question about reverb connections
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Minning Around</i>
<br />Red on the right worked. Thanks alot!
The amount of reverb is pretty weak though - I'm assuming this is normal for this amp?
Switch it around - see if it's any better.
I did switch it around. It doesn't work at all with red on the left. I also heard that the correct way to mount a reverb unit is to put it in a bag and then to mount the bag to the cabinet, not the reverb unit directly to the cabinet. Anyone know why this is so and would that affect the amount of reverb?
there is only one color
<br />I did switch it around. It doesn't work at all with red on the left. I also heard that the correct way to mount a reverb unit is to put it in a bag and then to mount the bag to the cabinet, not the reverb unit directly to the cabinet. Anyone know why this is so and would that affect the amount of reverb?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Probably a better way of doing it yes. It won't affect the <i>amount</i> of reverb as such, but will give the springs a bit more physical isolation - a good thing. Makes the reverb less susceptible to vibration, and cuts the possiblilty of reverb feedback. Matt (mpisarcik) did it himself I recall.
I believe the AD30s reverb is pretty mild, though they did introduce a mod around Feb '03 to improve the reverb. This could be retro fitted by techs if they contact Orange for the details.
http://www.orangeamps.com/forum/topic.a ... hichpage=1
Changing the valve in the reverb socket also affects it a bit, as will changing the reverb transformer.
It's pretty weak compared to other amps, but I think it's the perfect amount for general playing. If you do surf stuff, you'll want more, or a pedal, but i'm still amazed by how good my reverb sounds. No "boooiiing" sound off it at all, just a completely natural decay.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Probably a better way of doing it yes. It won't affect the amount of reverb as such, but will give the springs a bit more physical isolation - a good thing. Makes the reverb less susceptible to vibration, and cuts the possiblilty of reverb feedback. Matt (mpisarcik) did it himself I recall.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
yep..thats me!
I agree with what andy did. the bag helped to eliminate vibrations and giant reverb noises if you bumb the amp. the correct tube value ( and a good tube ) helped to bring out all that the AD30R had to offer. If you want more, i think that there are a few people that build aftermarket reverb tanks that are supposed to be better/longer reverb effects. do a search on this forum or the net and you're sure to get some hits.
yep..thats me!
Users browsing this forum: No registered users and 52 guests
