<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ocho8mila</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by fiveightandten</i>
<br />Lo,
Welcome to the forum. Congrads on the new amp, but i'm sorry to hear you're having issues with it. You bought a great amp, i'm sure we'll sort things out so you can start enjoying it.
<font color="maroon">thanks</font id="maroon">
1) The "ding" you heard sounds to me like a microphonic pre-amp tube.
<font color="maroon">do I have to chenge, or for now it's ok? </font id="maroon">
That amp uses 2 12AX-7's (also known as ECC83's). They're relatively cheap, and easy to find. So i'd just recommend replacing both of them. You can do a search for "tubes" and bring up old threads to get some opinions and recommendations. For that amp i'd recommend either Electro harmonix for a nice well balanced tube, Ei's for a brighter and more detailed tone, or JJ's for a darker more full sound. Though the differences aren't huge, they are noticable.
<font color="maroon">JJ sound good for me.</font id="maroon">
2) Does the knob make noise only when you turn it, or does the amp have a hum that gets worse as you turn the gain knob up?
<font color="maroon">the second one</font id="maroon">
These are 2 totally different problems, with different solutions. If the knob only makes noise when turning it, you need to clean the pot out. You can get a component cleaner at an electronics store. Get one with a lubricant in it. In the states, it's commonly called "Component cleaner and lubricant". I'm not sure how that translates into Spanish.
<font color="maroon">Italian would be better</font id="maroon">
If the amp has a hum that increases as you turn the gain knob up, then it could be a few different things. I'd replace both pre-amp tubes first and see if that cures it. If not, there could be a loose connection in the amp, a bad ground connection, or a noisy component (cap or resistor). Replace both pre-amp tubes and we'll figure it out from there.
<font color="maroon">so which should I take? JJ and which model?</font id="maroon">
As far as the amp not sounding good. It's really hard for me to say without hearing it. When a good sounding amp isn't sounding good, the first thing to do is always to replace the tubes, especially if you don't know how old they are.
<font color="maroon">the guy who sould it to me had the tubes replaced with some EH and some sovtek, actually I don't know which ones for pre and for final. anyway I'll go to buy the pre tubes. will it be easy to change them?</font id="maroon">
Take a listen to the sound clips in the sound clips thread and see if that's what your amp sounds like. If not, i'd replace the power tubes as well...have a good tech bias the amp up. If he's never worked on any Oranges, we can provide some pointers. They aren't like Marshalls or other amps.
<font color="maroon">Well I started to learn how to use it (FAC at the third position from left, bass at 1 o'clock, treble at 12, even presence at 12, gain all the way down and master at 2) like this I'm starting thinking of eliminating my od, fuzz, dist pedals...
![Wink ;)](./images/smilies/icon_wink.gif)
</font id="maroon">
<font color="maroon">I was thinking of bringing it to a man who is a sort of magic technician of these things but I don't know if he ever had an orange in his hands, what should I tell him?</font id="maroon">
I hope that helps. They're great amps. Hopefully we can sort this out for you and get the amp up and sounding nice.
<font color="maroon">I hope too</font id="maroon">
P.S. Here's a short clip of mine, for reference.
http://www.digitalsoundplanet.com/Membe ... 024357.mp3
SORRY I'M NOT VERY EXPERT OF FORUMS...
the thing in maroon is what I wrote...
which type of guitar did you use recording that clip?
can you date my orange head? as I wrote there is written 016xxx
another thing the echo send/return what position has it got in the circuit? before the pre? after? AT THE END???
thanks AGAIN,
<font color="orange"><font size="2"><font face="Book Antiqua">Lorenzo</font id="Book Antiqua"></font id="size2"></font id="orange"> ehe
