Brado
Post
by Brado » Sun Oct 26, 2003 12:16 pm
The head i have just purchased, has an 8ohm output, and a second output for another 8ohm cab, or a 4ohm cab. My cab is a behringer BG412H, which has mono 16 ohms, and stereo 8ohms. If i connect the head with both out puts to the left and right of the stereo inputs, this should work hunkydory right?
Meole
Post
by Meole » Sun Oct 26, 2003 3:33 pm
If the two 8 ohm outs from the head are connected to the cabs two inputs it will work fine.
If the cab is still in mono not stereo there will be troubles, one acts as an input, the other for daisy chaining another cab.
tomr182
Post
by tomr182 » Tue Nov 11, 2003 12:11 pm
how do you daisy chain cabs? ive often wondered how to do it, but never found out.
is it so you can have 4 cabs runnig at once off one head? or am i way off the mark
cheers
Meole
Post
by Meole » Tue Nov 11, 2003 1:47 pm
To daisy chain cabs, they need two 1/4 inch jacks on the back of the cabs.
One acts as an input the other a output.
The output from the amp goes to one of the jacks on the cab.
Another cab is hooked to the second jack on the back of the first cab, daisy chaining them.
You can do this forever; however, you must match your impedance after doing this.
Users browsing this forum: No registered users and 216 guests
