Hi lads, I bought a used Orange Rocker 32 from a local guitar store last month and yesterday it stopped turning on all of a sudden, I contacted the store and they said to check the fuse first and if it's something more than that they'll sort me out.
Anyway, I'm trying to remove the fuse but it doesn't seem to be coming out, I'm using a flathead screwdriver and I push the fuse holder and turn it counter-clockwise and it lowers but does not come out.
Also, what size fuse do I need?
I know the type but my local electrical store stocks the type in 20mm and 32mm.
Thanks.
Orange Rocker 32 - how to check fuse.
Re: Orange Rocker 32 - how to check fuse.
5mmx20mm 500mA slow blow for the HT fuse. Just a twist should loosen it, you might need a small screwdriver to lightly pry the holder out it. If it blew, there could be a problem with your tubes and hopefully nothing else. If you change it, and it blows again you need to service the amp. If it's the mains fuse, it's located in a small drawer like compartment on the power socket, with you just pry out with a screwdriver.
Users browsing this forum: No registered users and 247 guests
