So I've had the CR60 for about 2 months. Only been able to get it to a band practice twice but I've been having a terrible feedback issue. I'm thinking that the volume we play and the amount of gain I'm using is the culprit. Is this a situation where the amp simply isn't loud enough to do what I want it to do without the unplayable feedback and I need to go to the cr120? or is there something else I can do to help with the issue without having to trade the cr60 in?
On a secondary note I've also had the random issue of the toggle switch not switching the channel after I've plugged in the footswitch, is this common or is there a problem with the amp\footswitch?
CR60 Combo issues
Re: CR60 Combo issues
>>loud amps = feedback. Try standing in a different spot, or with your back to it and lower the gain a little?
>>I only have one amp with footswitchable channel switching, and when you plug the FS in it cuts the buttons on the amp, maybe it's normal for your cr60
Users browsing this forum: No registered users and 16 guests
