Rockerverb 100 MKII issue
kmdkad56
Post by kmdkad56 » Mon Nov 12, 2018 11:51 am
New to the forum and had an issue with my Rockerverb 100 MKII I hope I can get some help with. When I powered it up tonight, there was no output and the power light was not lit. The pre-amp tubes were glowing but not the power tubes. I'm wondering which fuses I should check and where they are located. Any help will be greatly appreciated. Thanks.
Re: Rockerverb 100 MKII issue
Post by Les Paul Lover » Tue Nov 13, 2018 11:41 am
My guess would be an issue with the spade connector or splicer supply the valve heater current to the power valve section.
To ensure that, you need to open the amp up, have it live and take voltage measurements, which is extremely dangerous.
Do you know a reputable tech in your area?
Users browsing this forum: No registered users and 96 guests
