Rockerverb 50 mki very low reverb
Posted: Tue Jun 19, 2018 9:24 pm
by Dxjxrose
I have to dime the reverb to get any reverb at all.... Ive replaced the tube checked cables made sure they are plugged in right the tank doesnt has broken springs and has contonuity on both jacks.... What else can i check? Anyone else have this issue? Please help
Re: Rockerverb 50 mki very low reverb
Posted: Wed Jun 20, 2018 12:28 am
by bclaire
Hmm... it sounds like you have checked all of the things I would suggest. I have had the little wire inside the reverb tank come loose from the tiny transformer inside the tank on a Fender but that would result in no sound - you have some sound, correct?
I think it may be amp tech time....
Posted: Wed Jun 20, 2018 1:12 am
by Dxjxrose
Yes ive taken the tank out everything looks cool the only odd part is one of the rca wires has continuity between the tip and shield one other doesnt
Posted: Wed Jun 20, 2018 6:14 am
by Les Paul Lover
Dxjxrose wrote: ↑Wed Jun 20, 2018 1:12 am
Looks like you have foind tour culprit.
Can you replace It?
Posted: Wed Jun 20, 2018 6:24 am
by Dxjxrose
Its soldered in and id have to remove the board to do so. And im not sure thats the issue as it is possable with it conected to the board that the circut has contonuity.
Posted: Wed Jun 20, 2018 12:38 pm
by Les Paul Lover
Tech time it is then.
It's difficult to help you further really, a shame. Good luck getting it sorted.
Posted: Wed Jun 20, 2018 2:02 pm
by Dxjxrose
Thanx... Im gonna try a new tank for giggles. But its going to a tech if that doesnt work. Unfortunately the only good tech in my area moved south
