AD30 Plate Voltage
Re: AD30 Plate Voltage
What about dropping the B+ voltage by using a 5Y3 rectifier?
Agreed. I was referring to the "just match the impedance" comment. As you clarified, there's a lot more to it than that. If I could just yank 2 tubes and plug into a different OT tap on my AD30, I would've done it a long time ago!Jondog wrote: ↑Sun May 27, 2018 1:40 amI put could in italics because it’ll work, but best with mods to the bias as well. I was partly thinking of the Dual Terror, although it’s bias resistors (150ohm/two tubes), but it is wired differently. One resistor/two tubes in push pull configuration. Best to do it right. I would mod the amp if I were to do that.fiveightandten wrote: ↑Sat May 26, 2018 8:45 pmWhat about the remaining tubes running off 150 ohm cathode resistors as singles (doubling the dissipation)?
A 5Y3 can't reliably keep up with the current demands of a 4 x EL-84 amp. It can supply roughly half the current of a 5AR4. IIRC, it would be right at the upper limit of the tube to run it in an AD30. I doubt you'd like the sound of lower voltage in an AD30. I know I don't. The pre-amp gets much too gainy for my tastes, personally.Farrerdale Records wrote: ↑Sun May 27, 2018 6:27 pmWhat about dropping the B+ voltage by using a 5Y3 rectifier?
Users browsing this forum: No registered users and 191 guests
