Hi guys, sorry for the noob question here. I recently bought a MK1 Rockerverb 100 with an Orange open back 2x12.
How should I be cabling from the head to the cab? One cable from the 16ohm to either of the two cab inputs?
Also how hot should my head be getting? It’s my first tube head and it seemed really hot after practice!
Cheers!
Rockerverb 100 cabling.
Re: Rockerverb 100 cabling.
You want a single speaker cable from 16 ohm out to any one of the cab's jacks. The other jack is for a second cab (and if you got a second 16 ohm cab, you would then plug the first cable into the 8 ohm out)
I thought as much. The main reason I asked is when wired that way at one point I lost nearly all volume? Then when I switched over to 8ohm it was fine?
Now that's weird... no idea.Robertgoodwin244 wrote: ↑Mon Apr 16, 2018 4:37 pmI thought as much. The main reason I asked is when wired that way at one point I lost nearly all volume? Then when I switched over to 8ohm it was fine?
