Hi guys,
Looking for same advice. Bought a mark1 Rockerverb combo very cheap recently. It was making a rattling noise at first rehearsal and my amp tech diagnosed an output valve and replaced it. In the last couple of days the volume especially on the dirty channel seems to have dipped and it seems very under powered. A/b it against the rocker 30 and the 30 blew it away. This was not the case 2 weeks ago, I a/b them and the Rockerverb sounded huge in comparison. Do you think this is valve related? I’m thinking I should just go for a complete revalve, give the amp some love. Are the JJ valves a good road to go down? Is there any others I should be considering?
Thanks in advance
Rockerverb problem
Re: Rockerverb problem
Is it the 100w or 50w MK I?
If 50w, the amp was designed around the JJ 6V6s, as they are the best current production 6V6.
Did your tech replace only a single output valve?
I would have expected him to recommend at least the pair to match them, or better yet the quartet.
Hi,
Yes it is the 50 and he just replaced one as he had just one brand new one at his place. I have just ordered the full replacement JJ valve kit so hopefully this should sort it. The amp sounded great last week but I don’t think I’ve yet heard it at its best so looking forward to it
You will need to get it biased after changing all the power valves.
On a side note, your tech should really have changed at least the pair and rebiased it. Even if that meant waiting a few days for the correct valve to show up.
Users browsing this forum: No registered users and 212 guests
