TH100h dirt channel
Smeigel_12000
TH100h dirt channel
Post by Smeigel_12000 » Fri Feb 02, 2018 3:24 pm
Hi everybody,
I'm Michiel from Holland. I'm new to this forum but secretly allready have read a lot of information before registering.
Recently I bought myself a second hand TH100h with closed back ppc212. An awsome set and I'm very happy with this amp. I do have an issue though. For some reason I feel the dirt channel is to low in volume compared to the clean channel. In my band I run the clean channel around 25% while dirt channel is at 75% to equal volume. When I turn on my boost pedal on the dirt channel (fx-loop), that's where the dirt channel comes alive.
Do I have bad preamp tubes or is this just the design of this amp?
Cheers,
Michiel
Re: TH100h dirt channel
Post by bclaire » Fri Feb 02, 2018 7:01 pm
It's never a bad idea to retube preamp tubes when you buy a used amp... it could easily be just tubes.
Post by Jondog » Fri Feb 02, 2018 10:03 pm
Maybe tubes, but you have to treat each channel like a seperate amp (because they actually kind of are. Different signal path until the power amp) and adjust accordingly.
Smeigel_12000
Post by Smeigel_12000 » Sat Feb 03, 2018 9:04 am
Thanks for the reply’s.
So retubing is a good plan anyway. Then my next question (and maybe a noob one), is it hard to change preamp tubes? If I’m right only power amp tube need a bias do they? Anyone knows of a clear manual? Sorry for all the questions 😏.
Cheers
Post by Jondog » Sat Feb 03, 2018 12:15 pm
TH100 will need to be biased for power tubes. Not preamp tubes. The aluminum shields come off with a slight twist, the preamp tubes just gently wiggle pulling up at the same time. Pay attention to the orientation of the pins when taking them out. Theres 9 and a wide space between two of them that needs to line up in the socket when installing presmp tubes.
Smeigel_12000
Post by Smeigel_12000 » Tue Feb 06, 2018 2:55 pm
Anyone of you changed the preamptubes (12AX7) for 12AT7 tubes? If yes what were your findings?
Users browsing this forum: No registered users and 89 guests
