VT-1000 Valve Tester Fails All Tubes
Posted: Fri Jan 12, 2018 9:56 pm
by s-fresh
Hello All, This is my first post here. I have a VT-1000 Valve Tester. It's been great as a simple way for a layman to test and "match" tubes, but recently it has stopped working. When I put a tube in, select the type, then start the test it looks like it is working for a while, then fails the tube. From that point on every tube I insert (pre-amp, EL-84, or bigger power tubes like 6L6 or EL-34) immediately fails. If I unplug the unit for a while then plug it back in, it will look like it might work again then fails the next tube within a few seconds. From there all tubes fail immediately again until I unplug the unit for a while. These are all good tubes I have tested before without any issues.
I bought this unit used and I doubt there is any warranty a this point. Any ideas where to start in figuring this out? I hate to give up on the unit as it was expensive and I've got a lot of benefit out of it.
Thanks in advance for any ideas!
Re: VT-1000 Valve Tester Fails All Tubes
Posted: Fri Jan 12, 2018 10:53 pm
by bclaire
Hmm... not sure what to say about this without thinking about it for a bit.
I doubt there's anything remotely user-friendly in there to check and I haven't seen a schematic for one. I would try contacting Orange USA directly and see if they can offer some advice (maybe call?). I have never opened mine up so I don't know what it looks like in there. Sorry for not being more helpful - if I think of anything, I'll let you know.
EDIT: where are you located? (Contacting Orange USA won't work if you're in the UK) :mrgreen:
Posted: Sat Jan 13, 2018 4:51 am
by s-fresh
Thanks for the reply, bclaire! I am in sunny California, USA. I'll send them an email as well in the hopes they can provide some direction.
Posted: Mon Feb 15, 2021 8:45 pm
by ilcaccillo
Hello,
I have the same issue that you described with this unit,
unfortunately they all seem to fail.
I tried to contact Orange several times so I could send the unit to repair but never got a reply.
If anyone knows how to contact the Orange repair department please let me know.
Were you able to send your unit for repair?
Posted: Tue Feb 16, 2021 11:24 am
by bclaire
Hello,
Sorry you have had issues with your tube tester - since you posted the same thing in like, four threads this morning. Personally, I have had nothing but good results with mine.
