I'm currently living in the UK but I might be moving to Canada so I need an amp where I can change the voltage.
I cant see a switch anywhere but the manual says Please ensure your amplifier is switched to the correct voltage for your country. If unsure please consult your dealer.
Is there one hidden inside somewhere?
TH30 Head. Does it have a 110v/240v switch in it anywhere?
Re: TH30 Head. Does it have a 110v/240v switch in it anywhere?
Most of the modern Orange amps have a small red slider switch that switches between two different voltage settings (different voltages among different models). But any of the photos I see of the TH30 don't have this switch oddly enough. I saw some photos of the internal wiring and the leads that are used for the voltage selection are just taped off. Wonder why they didn't put the switch on the TH30??
It'll look similar to this if it has one
Yeah I know what they look like I just cant see it anywhere on the outer casing. if there is one its inside somewhere.
Probably not one. It's an easy re-wiring job though. Several threads here about how to do it.Hammerheart wrote: ↑Tue Nov 28, 2017 11:30 pmYeah I know what they look like I just cant see it anywhere on the outer casing. if there is one its inside somewhere.
Sooner
AD1512 Serial No. 001
Users browsing this forum: No registered users and 107 guests
