Distortion problem with CR120
I get a feedbackish sound when I play chords on my middle strings... happens on all my pedals and the amps dirty setting... i have sample recorded on my phone bad I can't post it on here...
Re: Distortion problem with CR120
Try using the guitar without the pedals. Try a lesser distortion sound. Any difference? It could also be that your pickups aren't potted and in a high gain setting they're going microphonic.
It plays fine clean... and any chord based off the E plays fine... it happens really bad on the third fret on the A string... guitar is a grestch hollow body... I did turn down the distortion and it still happens
All bets are off when it comes to a hollowbody guitar. That feedback is probably a howl where the back and front are vibrating sympathetically... there are many ways to "cure" it, but most of them I wouldn't try. For example, fitting a dowel between top and back through the soundhole is one way; packing it full of insulation is another; but I wouldn't want to do them....Aaron lucas wrote: ↑Mon Sep 11, 2017 2:27 pmIt plays fine clean... and any chord based off the E plays fine... it happens really bad on the third fret on the A string... guitar is a grestch hollow body... I did turn down the distortion and it still happens
I can send you a recording if you have Facebook messenger. Pm me your details... that way I can know if it's the guitar... a friend of mine thinks it's the fret
It's not the fret. You're playing a hollow body guitar which is prone to feedback. Also, Gretsch pickups are voiced for a more trebly sound so that's contributing as well.
I can confirm its the guitar. I had a nice electromatic for a while. Anything more than a light crunch would feedback. Hollow bodies are meant to resonate. So certain notes will sympathetically resonate with the body and the distortion will compress it and make it more noticeable.
My cat loves the Orange tone!
Users browsing this forum: No registered users and 76 guests
