Hello, I'm new to Orange Amps and to this forum. Sorry if this question was already answered but I didn't found an appropriate answer.
I have a Micro Dark Terror and I'm trying to use it as a clean power amp only. I'm connecting my guitar to my pedalboard and it to the FX-Loop Return input. The sound seems to be clear, as I'm bypassing the preamp section, but the problem of doing this is that the amp volume knob doesn't work. I have to control the volume through my pedalboard output level. Is there another way to bypass the preamp section to eliminate distortion?
Sorry for this dumb question: if I remove the preamp valve will the power section work without distortion?
Any help will be welcome, thank you!
Micro Dark Terror: How to disable preamp?
Re: Micro Dark Terror: How to disable preamp?
Not really. What you can do is set the gain as far up as it goes without distortion - and them use the master volume as volume control.
That's all you can do really.
Put a volume pedal as your last pedal. You do have to realize you're trying to do something it wasn't designed to do and there are better options out there.
Thank you guys!
Users browsing this forum: No registered users and 242 guests
