LP / tiny-terror /MIDS
Any TT owners experience real high mids and high treble? I've got a TT combo with a celestion 12 and JJ tubes (new) throughout. No matter what I do (with my epiphone LP black beauty, the mids /treble /high end is bordering on ear piercing on all three pick up positions at any volume (on the amp). A MOJO MOJO pedal thickens it up a bit, but I want the tiny terror to sound like I know it can. Am I missing something? Guitar problem? Amp problem? Help
Re: LP / tiny-terror /MIDS
Hi Aj_TinyTerror, and welcome.
Do you have the same with that guitar through other amps? I'm wondering if it is to do with pickup height? May be that they are adjusted too low / far from the strings. Then you'd indeed have too little low end so that the upper frequencies would dominate. Might just be your guitar needing set up properly...?
I have a strat that is maybe, a weeee-bit better, but yes, still pretty schrill. I have and continue to play around with pickup height, pole pieces, top wrapping, tone knobs, etc. ----just can't find that sweet spot. Pre amp tubes maybe...? I have newer JJ's all the way around
Did the amp sound different before you changed the tubes? Is this a new amp, or you've owned it for a while and know it sounds better than it does?
I didn't change the tubes - I got it re-tubed with a new celestion 12. The amp is from 2012 and that work was done a year ago, I got the amp two months ago.
Bit of confusion here. So it has sounded this way since you've had it? What Celestion 12" model? Theres over a dozen different models. Also if it's a new speaker, it's going to need to break in. Typical of some new speakers to be a bit shrill.
Users browsing this forum: Google [Bot] and 225 guests
