Hello,
I have a fuse issue on my brand new Rockerverb MKIII 100 Head.
It has been 2 times that the main power fuse blew off.
Before sending back this monster to the shop, i want to make sure which fuse is the best for my amp.
Could someone tell me which one to choose between those 2 (I am using 220 V),
- T2,5A 250V in Ceramic (temporised in ceramic)
- T2,5A 250V in Glass (temporised in glass)
Or maybe i am wrong...
Thank you very much,
Fred
Fuse issue Rockerverb MKIII 100 Head
Re: Fuse issue Rockerverb MKIII 100 Head
Do you mean the plug fuse?
Not the fuse in the amp, but the one in the plug itself?
Hello,
No i mean the fuse itself (the one i took of was in glass..)
Thanks,
Fred
Thanks,
Fred
- Attachments
- T2.5A 250V ceramique.JPG (8.56 KiB) Viewed 2484 times
- T2.5A 250V verre.JPG (10.26 KiB) Viewed 2484 times
- IMG_0025.JPG (102.58 KiB) Viewed 2484 times
That looks like the HT fuse, not the main power fuse which is located in the drawer on the iec socket. HT fuse looks to be rated 1.6 amps. If it keeps blowing there is an issue with the amp.
Thank you very much, but my question is which fuse is appropriate, the ceramic one or the glass one ?
i have no idea from my point of view
Either is ok. Just make sure you have the proper voltage and current rating.
You may have a case of early power valve failure. They usually get the fuse blowing when they develop issues.
I would contact your dealer and explain what has happened. They probably will want to see the amp again and the check the valves out, and possibly rebias if they swap the faulty pair.
Last edited by Les Paul Lover on Wed May 17, 2017 8:09 am, edited 1 time in total.
Ok, thank you very much !
Users browsing this forum: No registered users and 215 guests
