No logical reason after I read your logical question hahaha
I put it back together and it's great!
Both channels are identical, however I use different tubes in each channel and will mess around with different settings.
At the moment I have ECC81s in CH1 and CV4004 in CH2, with CH1 being a bit on the bright side and CH2 being heaven as a place on earth.
I do notice what sounds like PT hum on CH1, as if it's under heavier load while CH2 is dead quiet, could that be because of the different pre-amp tubes or does it warrant further investigation?
CH1 is unmodified in all aspects.
AD30TC channel 2 68k ohm resistor
Users browsing this forum: Google [Bot] and 204 guests
