Hi there
Does anyone here know if I can use yellow jackets YJS in my orange Ad50 custom shop amp thus replacing my el34´s with el84´s and thereby making the amp a bit quiter ? As I understand the YJS model that I have of the yellow jackets are for amps with fixed bias. My ad50 is fixed bias in the 30 watt setting and in the 50 watt setting it is cathode biased. I only use the 30 watt setting.
Yellow jackets YJS in my Orange Ad50 Custom shop?
Re: Yellow jackets YJS in my Orange Ad50 Custom shop?
Sure that isn't the other way around?kars0747 wrote:Hi there
(Cathode biasing being less efficient = lower power output than fixed biasing!)
Hey Andy. Sure enough. It´s the other way around. Still do you know if I can use the yellow jackets YRS which are for fixed biased amps as far as I can tell from their web page. That is if I use the 50 watt setting then.
Clearance may be an issue. You should measure the available space and see if they will fit. You might have to slide the chassis out to install them and slide it back in. Maybe.
If they fit they should be safe to use. I see THD don't make them any more, having sold the line. But from their old page..
I see there was an extra connection needed for cathode biased amps, so indeed run fixed biased for what has now become the YJS model:
https://www.yellowjacketstc.com/yellow_jacket/yjs" onclick="window.open(this.href);return false;
If space is tight:
https://www.yellowjacketstc.com/yellow_jacket/yjshort" onclick="window.open(this.href);return false;
I don't know if the new manufacturers have changed anything but I'd trust THD on that.http://www.thdelectronics.com/product_page_yellowjacket.html wrote:Will they hurt my amp?
No! Yellow Jacket® converters are safe for all amplifiers and transformers. As all Yellow Jacket® Converters internally limit voltage and current they put no extra strain on amplifiers' power and output transformers or internal components.
If space is tight:
You can try them as others have said (if they fit) but I imagine you'll be disappointed. I've never liked the results. They tend to make an amp sound flat and mushy in my experience.
Wow. I once owned a fender hot rod deluxe 40 watt which was too loud. I got the yellow jackets and was pleased. Now I am the proud owner of an orange ad50 custom shop which was too loud. Since I put the yellow jackets in - what a difference. I can turn the master up 75 % and add gain (about 30-35 %). Cannot stop smiling. The best of Vox and Marshall blended into my beautifull Orange. I am so pleased. Run it with a mix of a vintage 30 speaker and and a g12H 30 greenback (75hz)in my orange cab plus a homemade extension cab loaded with an old g12h30 greenback from 1971. Thanks for your help guys. And finally. It has taken me years to do this. Just plug in and play and use the volume knob to add gain and a little more power.
Nice. I've never actually used these. How is the low end and overall note heft with the YJs? Most EL84 amps use lower value coupling caps, as those tubes don't pass low end like bigger bottles. I'm curious as to what happens with an amp that's voiced for big bottle tubes and is run through 84's.kars0747 wrote:Wow. I once owned a fender hot rod deluxe 40 watt which was too loud. I got the yellow jackets and was pleased. Now I am the proud owner of an orange ad50 custom shop which was too loud. Since I put the yellow jackets in - what a difference. I can turn the master up 75 % and add gain (about 30-35 %). Cannot stop smiling. The best of Vox and Marshall blended into my beautifull Orange. I am so pleased. Run it with a mix of a vintage 30 speaker and and a g12H 30 greenback (75hz)in my orange cab plus a homemade extension cab loaded with an old g12h30 greenback from 1971. Thanks for your help guys. And finally. It has taken me years to do this. Just plug in and play and use the volume knob to add gain and a little more power.
Hi Nick, I just add a little (10-15%)low end on the amp (around 2 o´clock on the bass knob now) and I do not miss a thing. I guess it all depends how loud you can play with the band. I often find a 50, 40 or 30 watt amp to be way too loud for my needs and I can not recommend experiencing with yellow jackets enough. It is the second time I´ve done it with an amp , and both times I am blown away by the result
Users browsing this forum: No registered users and 107 guests
