Terror Bass 1000
Terror Bass 1000
Love my TBass but need help. Lately the amp warms up and plays fine for a short period of time then fades out to a fraction of its power. I replaced the preamp tubes and the problem remains. It is a powerful amperage that a weak power source may be an issue but it happens in several locations so not just the source. Thank you for any prudent help
Re: Terror Bass 1000
I'm having the same issue. Have you found the cause or a fix?
Howdy!
I'm having the same issue as well. Have either of you found the root cause?
Thanks,
V
Thanks,
V
Hi,
I'm having this same issue with my Bass Terror, has anyone found the cause?
I have the same issue with my Tiny Terror 500. I excluded the following possible sources of the defect:
- Bass Guitar
- any cables whatsoever
- effects
- tubes
- settings
- tube warmup
My local tech service and repair says that they don't know the solution either. They could make a guess and switch a coil/inductor "between" power relay and circuit board (i am no expert on this matter) for 200€. Not sure if this pays off. Any ideas?
- Bass Guitar
- effects
- tubes
- settings
- tube warmup
Has anybody actually contacted Orange on this? Maybe an idea???
They are usually great at helping with any issues. I'd be interested to hear what they say...
It may not apply, but I had a similar issue with my AD200B a few years ago. You may want to have your tech check if the power connection for the 12AX7 tubes is a Molex style connector as opposed to a soldered connection. If it is have him try clipping off the connector and soldering the connection for both of the tubes. These connectors can corrode internally and lose conductivity as they heat up.
In the case of my AD200B, it was the connectors for the power tubes that was the issue but I believe the tech replaced all of the connections with soldered joints (all 4 power tubes and the 3 preamp tubes). That may not be the issue here but it's worth a shot to find out. I do know that Ade Emsley mentioned in a NAMM interview recently that Orange is now moving away from all plastic connectors starting this year, so I believe it has been a known issue. As Andy mentions above, Orange may well already have some things for your tech to troubleshoot as well.
mmmmmm drop
Guthrie Matthews Method
Users browsing this forum: No registered users and 255 guests
