Retro 50 Schem.
- Orange Expert
- Orange Expert
- Orange Expert
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by timboardman</i>
<br />true, true.. but it's just a bit of a hassle trying to make one from mine, by looking at the wiring. they gave someone (kannibul?) a RV schematic, as he owned it and wanted to check something, so it could work like that for me and the retro, but it's unlikely, i fear.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Ehh...just draw it out. If you own the amp it won't be that difficult. It's a single channel amp, probably a pretty simple circuit if it's like every other Orange amp out there. I bet you can do it in an hour.
- Orange Expert
<br />quite possible.. but i don't really want to take it apart and hurt it... i'm treating it quite like a child.. which is a little embarrasing.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I mean this in the nicest way...if you can't pop the chassis out of the headbox on that Retro 50 without hurting it...you probably shouldn't be attempting to build an amp.
- Orange Expert
Gotcha.
Actually...if you don't mind me asking...why do you want to clone the amp if you already own one. Don't get me wrong, i'm quite curious to see a schematic as well...just wondering.
If I ever get a few hours with one i'll be sure to pop it open and trace everything out. Though I doubt that'll happen any time soon.
- Orange Expert
basically because i'm not playing the nicest venues, and i've had a couple of friends on the circuit who have had their heads stolen from the backstage area, or someone put a pickaxe through the side of their van and made off with their amps and guitars. so i'd quite like to have an amp that sounded like my retro 50, without the worry about the fact it was my actual amp that was worth a lot of money and in a bit of danger..
<br />basically because i'm not playing the nicest venues, and i've had a couple of friends on the circuit who have had their heads stolen from the backstage area, or someone put a pickaxe through the side of their van and made off with their amps and guitars. so i'd quite like to have an amp that sounded like my retro 50, without the worry about the fact it was my actual amp that was worth a lot of money and in a bit of danger..
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Ahhh, I see. Well, let me know if you get a schematic...i'm real curious to see that one.
In all honesty, and not to take any business away from Orange. But for your purposes, you can just take the amp to a good tech and have him clone it for cheaper than you bought the real one. I'd make that amp, from scratch (having to do all the research and trace the real one out) for $1500US, top notch parts. You may be able to find someone to do it cheaper.
Or...just get a road case with a lock, and chain the handle to your 4x12 when you're not around it.
- Orange Expert
<br />i've done electronics to a-level standard, which means all my soldering and putting together should be up there... it'd just be my first valve project, which puts me off a little.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">If you know how to solder and you've been inside some well built amps so you know what's good and what isn't...you'll be fine.
For my first amp I built a Hiwatt DR504 clone. Right off the bat, it worked fine and sounds fantastic. You can't even tell it's a clone. People who see it say, "what year is that Hiwatt?". Even from the chassis pics, it's hard to distinguish it's not real.
If you take your time and do it right, there's definitely no worries if you know what you're doing. You have the real thing right in front of you. You can even order an extra set of transformers from Orange, and buy the same caps they use. There's no reason why you can make it technically, exactly like the real one.
I don't normally encourage people to build an amp (it's not an easy task). But if you know what you're doing, go for it. They don't make the Retro 50 anymore, so I don't really see anything morally wrong with cloning it for yourself.
Users browsing this forum: No registered users and 189 guests
