mattias
Post
by mattias » Wed Sep 14, 2016 6:30 pm
Hi,
I'm thinking of trying a 12AT7 valve in the V1 position of my Orange OR100 from 2015. The purpose is to test how the amp reacts and sounds with a lower gain valve in the first position. I look at the OR valve position diagram available here,
https://ln-media.orangeamps.com/wp-cont ... pdf?05b1f9, and I see:
- There is one valve called 1 2 CLEAN
- There is one valve called 1 2 DIRTY
Does that mean that the clean channel and the dirty channel doesn't share any pre-amp valves at all other than the FX-loop and the phase inverter (PI)?
Post
by Jondog » Wed Sep 14, 2016 9:04 pm
Correct.
Snapjaw79
Post
by Snapjaw79 » Wed Jan 18, 2017 8:22 am
You ever give the 12at7 a try?
Orange or15
Orange or100
1973 Laney Supergroup
1973? Sunn model T 1st gen
70's Traynor ygl-3 Mkiii
orange and marshall cabs
Sg's and Les Paul's.
and some fenders.
mattias
Post
by mattias » Wed Jan 18, 2017 8:32 am
Unfortunately not. I did some more reading and then I did some thinking. One could describe it as a mental journey where I ended up in that all I've searched for was the early Marshall sound. So... I sold the OR100 and bought a Marshall Vintage Modern (JTM45 style amp with FX-loop) instead. Now I don't need to change tubes...
Post
by Les Paul Lover » Wed Jan 18, 2017 4:40 pm
mattias wrote:Unfortunately not. I did some more reading and then I did some thinking. One could describe it as a mental journey where I ended up in that all I've searched for was the early Marshall sound. So... I sold the OR100 and bought a Marshall Vintage Modern (JTM45 style amp with FX-loop) instead. Now I don't need to change tubes...
Love it!!!
All that matters is that in the end, you have the tone you wanted!
Bensnake
Post
by Bensnake » Wed Jan 18, 2017 9:56 pm
mattias wrote:... I sold the OR100 and bought a Marshall Vintage Modern...
Bad move.
Bad move.
You do realize you need'em both, don't you?
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
mattias
Post
by mattias » Thu Jan 19, 2017 7:23 am
Les Paul Lover wrote:Love it!!!
This is exactly what I try to go by.
Bensnake wrote:Bad move.
Bad move.
I will probably regret it some day. Though, the OR100 is a beast with a bottom end that I'm not worthy of
. Some day I'm hoping to buy a more vintage flavored Orange. Remember, it's better to collect amps than guitars. Guitars can only be played on one at a time whilst amps can be played all at the same time.
Bensnake
Post
by Bensnake » Thu Jan 19, 2017 7:06 pm
mattias wrote:Remember, it's better to collect amps than guitars.
Talkin' to me?
2 x PPC412
Bax B. | Amp D.
Vox AC30C2X + V212C
Users browsing this forum: No registered users and 12 guests
