Crush 35RT No sound through main speaker
I have one of the first Crush 35rt amps that were made and now after one true gig as it mainly sat at home for practice the main speaker does not work. I saw some others with this same issue. Since it is out of warranty I took a peek inside and found no loose connections. Also I tried a different speaker that was 4ohm like the one that came with it and nothing. The boards all look in great condition...not sure what to think. The headphone jack works. When I last used the amp it worked good and the volumes were set midway since it was miked. I would've thought perhaps in travel something had loosened, guess not. I'm out of ideas...what a bummer.
Re: Crush 35RT No sound through main speaker
I'd call Orange anyway and see what they will do for you, if its a known issue they may just honor the repair out of good faith.
Users browsing this forum: No registered users and 219 guests
