Wire output jack for 16 ohm and 4 ohm on PPC212
I am looking for some advice on rewiring my 212. I am only going to be using it at home and looking at it being the only cab left at home. I currently have a Mini Rectifier that runs 4 and 8 ohms and a Jim root Tiny Terror that does 16 ohm and 8 ohm. Has any one ever tired the one side of the jack with one impedance and left the other side the same? Or should i just by the rectifier 212 that is just 8 ohm?
Re: Wire output jack for 16 ohm and 4 ohm on PPC212
You're not talking about running two amps into one cabinet, right? Because that is a big no.
Please explain again - I'm not sure what you're asking....
Is this what you are driving at?
No not 2 amps at the same time but being able to use different amps. 1 at a time on the same cab.
Thanks jontheid that's what I am looking for. Just curious if anyone has done that with the existing jack plate.
Thanks.
Thanks.
I have a 4x10 bass cabinet that I've been running with a switch that converts from series to parallel. The cab runs 2Ω or 8Ω. It's worked for like 20 years. So, it can be done.
Yeah, I did the same thing with a Fender cab... wasn't sure what he was initially asking.Gladmarr wrote:I have a 4x10 bass cabinet that I've been running with a switch that converts from series to parallel. The cab runs 2Ω or 8Ω. It's worked for like 20 years. So, it can be done.
I guess I forgot to say it's a ppc212.
Very expensive, but you can always install one of these. Dimensions are there to check compatibility.
https://www.tubesandmore.com/products/j ... stereomono" onclick="window.open(this.href);return false;
Users browsing this forum: No registered users and 69 guests
