I just picked up a used cab and the wiring appears to be messed up. I only looked when (looking from the back of the cab) the top right speaker wasn't working. I tested it with a multimeter and it measured proper ohms so I think the wiring is just messed.
All 4 speakers are 16ohm, and I would like to wire it as 16ohms mono. I found some diagrams on the internet which seem pretty strait forward but look nothing like how mine is wired. My cab has 2 inputs on the back but are unlabelled, I assume that is to make it stereo input maybe?
Here is diagram I drew up of how it's currently wired.
https://app.box.com/s/4q9ewrbulnns4935ch5vtixbfmu4ccvo" onclick="window.open(this.href);return false;
I assume that is wrong? Should I just disconnect everything and re-wire something like this
To do that do I need to remove the wires between the 2 input jacks? I don't need stereo input
Help with 4x12 wiring
Re: Help with 4x12 wiring
Yikes. Somebody messed with that cab. Rewire it like the image you found online...
Thanks. Should I connect the + and - the diagram has to just the first input on the cab. Assuming I don't need stereo wiring should I just disconnect the 2nd input?
Here is a pic I took of the 2 inputs for the cab.
https://app.box.com/s/byc13ig1uqtn8fyt59kfrtgdx9og492s" onclick="window.open(this.href);return false;
There is a white wire connecting both the inputs which you can see, but also a black wire connecting them which the crappy lighting in the picture didn't really capture.
Actually after looking at it closer, I think the tip on the 1st input jack is connected to the tip on the 2nd. And same with the sleeve or ground. So I think its just intended to give you the option to plug into either plug but not both. Does that sounds like a common setup?
It is so you can 'daisy chain' two cabs together. It wires them in parallel.
Users browsing this forum: No registered users and 222 guests
