I'm looking to re-cap the power supply filter capacitors on my AD15. I wanted to see if others here have done this and what they selected for replacement caps.
I've been looking at the Panasonic EEU-EE2W series, EEU-EE2W470S (47uF) and EEU-EE2W220S (22uF). However, I'm not sure that the ripple current of these is high enough. The 47uF is spc'ed at 1.2A, and the 22uF is spec'ed at 945mA. I haven't done any ripply current calculations on the AD15, so I'm not exactly sure what is needed, but if anything I'd rather be well over the needed ripple current if possible, which I'm thinking would need to be at least 1.5A... but that's a guess. Any help is greatly appreciated!
Anyone Re-Cap an AD15?
Re: Anyone Re-Cap an AD15?
Funny, I was considering that when my AD15 was in bits the other day, I couldn't help thinking that replacing caps andbkijesbshould be done now....
But Then they looked all well, and the amp sounds incredibly good, so thought I might as well not mess with it any more than needed.
Are you really intent on doing it? I'd be interested to hear your thoughts if you do it.
Or is something going wrong with your amp?
In my circle of music friend there are four AD15s that I see regularly, three of which I've opened up and have worked on changing tubes, speakers, and tried to de-squeal. One of them has a problem where the output is extremely low. It's not mine but my friend asked me to take a look at it. Two of the 47uf caps are a little puffy on the end of the can, so I'm looking for replacements (figured I might want to preemptively change out the caps in mine as well). There are a lot of axial caps (leads coming out either end of the cap) but there radial styles seems more limited. Capacitor prices are also all over the place, so I'm trying to go by the specs I want, preferable going overkill on the ESR and ripple current. The schematics on-line don't say much about the output transformer in the circuit, but the main's fuse in 2A so I figure getting close to that would be reasonable. However, I don't really know... I only have a very basic understanding of tube electronics and power supply design... I don't know enough to analyse the tube circuit schematics available on line to calculate the actual ripple current on the 3x 47uF and 1x 22uF cap, so I'm hoping someone on here can help me out.
The HT fuse is only rated at 1A.
Sorry I'm not much help really. My 3 47uf are branded by teapo
If you can find the specs of those, you'll probably find how much you need?
Since you "maintain" a stable of four AD15, have you had any issues with the valve heater connection in the past with them?
Surprising no, I've seen plenty of people having issues with it on-line though. I did add extra glue my connectors one time I had it apart.
Very low output from an amp is unlikely to be failing psu caps.
It sounds like that amp needs troubleshooting form a tech.
Also, do you know how to discharge caps safely?
Have you got a voltmeter/multimeter?
If you don't I wouldn't try to change the PSU caps yourself.
Regarding capacitor makes, I'd avoid JJ - they have only 1000 hrs rated life!
F&T are supposed to be good, aren't too expensive, and last longer.
Yeah, I have a cap discharge box I built, and there could definitely be other problems with the amp, but these caps are puffy and need to be replaced. I've ordered some of the Panasonics. I've gotten some feedback from other forums where people have used them without issue. I'll let everyone know how it goes.
Cool, looking forward to hear your thoughts on the new capacitors. Hope that solves the issue and the amp sounds better than Ever!!!!
I had a look at the specs for the Panasonics - they last for ages! Longer than F&Ts for sure.
Good find.
Good find.
Users browsing this forum: No registered users and 100 guests
