Orange Rockerverb 100 MK2 (MKII) noisy! preamp gain noise
Alright, so I have been trying to tame the beast that it white/preamp noise. I even run a Rocktron Hush C in the effects loop and at like volume 1.5 it's awful. like, I have to switch to the clean channel between songs because it drives all of us insane.
so in my rack i have noticed I generated a little more noise due to my BBE Sonic Maximizer (used to modern the amp up a touch), so to ensure it's not a rack system issue I run a Rocktron Buzz Kill which kills the noise frequency created in racks.
further, it did this with the stock tubes, so I had all the tubes replaced with JJ tubes ...which yielded no difference. I later had to have the amp taken in for service because the ribbon cable inside came off of the circuit board and I asked the tech if he noticed the noise. they said they did and that it's "normal" because I run the gain around 8.5...
so is this actually "normal" for an Orange? because the only other amp I've owned that made this much noise was an original Marshall JCM800 2203 haha.
or do i need to re arrange my rack setup for noise suppression? i don't use much here's how I have it set up currently.
Guitar > Orange input > Effects Loop Send > Rocktron Patchmate 8 > Rocktron Hush Super C > BBE Sonic Maximizer > Rocktron Buzz Kill > Eleven Rack > Effects Loop Return.
the Eleven Rack is only used on the clean channel which I only use on 2 songs so I haven't justified a real effects processor yet haha
thoughts? suggestions? the noise lately has been driving me crazy lately haha
Re: Orange Rockerverb 100 MK2 (MKII) noisy! preamp gain nois
There's a few things might be worth looking at. Have you ever tried a power conditioner? Could be a ditry mains noise.
The only thing I could get to tame the noise on my old 6505+ was an ISP Decimator. Having said that I've never used a Hush Super C.
Thanks for the response, I guess I could have mentioned I am using a power conditioner already.stuart_tate41 wrote:There's a few things might be worth looking at. Have you ever tried a power conditioner? Could be a ditry mains noise.
the Hush Super C is quite powerful in it's noise suppression... I am going to borrow my friend's Boss NS2 and ISP Decimator this week to try other suppressors but I am not expecting much change. I guess I should check back after I am able to try that?
I'm guessing you've gone through all your instrument cables and patch cables?
Gosh! Gain at 8.5! What happens when you back the gain off just a tiny bit (aside from getting better tone... )?
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
yeh, i've replaced every cable in the rig with a decent quality cable. no monster cable type stuff but at $15 a cable for what I used I think I have enough wrapped up in cables haha! I originally bought a cheap set of patch cables from Guitar Center and replaced all of them in the matter of hours...stuart_tate41 wrote:I'm guessing you've gone through all your instrument cables and patch cables?
haha! ...I knew it was only a matter of time I caught something for that! well I play a Sanctuary/Nevermore type of metal mixed with some Megadeth and Testament influence so with that being said I play a 7 string. we're tuned to A#/Bb and my guitar is a Carvin SCB7 with a mahogany neck, mahogany body and a swamp ash top. I guess if I share anything with Dimebag Darrell it's my lust for gain. Had the Dual Dark been released when I bought this Rockerverb new I would have went with that instead.Bensnake wrote:Gosh! Gain at 8.5! What happens when you back the gain off just a tiny bit (aside from getting better tone... )?
if I roll back on the gain to just hit the 4th gain stage the 7th string sounds bassy and not like a guitar, but still noisy. personally I am a 6 string player but the guy I play with got me into 7's, enough to have a Carvin built to sound how I wanted my tone to be
well i did a 7 minute video running through everything i could think of with the amp, it never really does silence up to an acceptable level like my other guitar player's ENGL does. he uses the onboard suppressor and the suppressor in his AxeFX and dead silent.
http://youtu.be/-W1tJMqJ-bA" onclick="window.open(this.href);return false;
Oh man that's a lot of noise! You say you've changed the tubes and it hasn't changed?JustinG60 wrote:well i did a 7 minute video running through everything i could think of with the amp, it never really does silence up to an acceptable level like my other guitar player's ENGL does. he uses the onboard suppressor and the suppressor in his AxeFX and dead silent.
Have you plugged that engl into your set-up in place of your orange?
Do you get the same noise when you plug the guitar straight into the amp?
yep, changed the tubes even though they did not need replacing hoping it would clear up some noise but made no difference.stuart_tate41 wrote:Oh man that's a lot of noise! You say you've changed the tubes and it hasn't changed?JustinG60 wrote:well i did a 7 minute video running through everything i could think of with the amp, it never really does silence up to an acceptable level like my other guitar player's ENGL does. he uses the onboard suppressor and the suppressor in his AxeFX and dead silent.
I have not plugged the ENGL into my setup but I have run multiple other heads through my rig and silences to an acceptable level or gone completely...
same noise when i plug directly into the amp? no, it's WORSE! add all the static, add all the hum and then in god awful squeal. that's what it's like with out my noise suppression setup. i guess i am about to try calling Orange but I don't think I registered the amp online to get the extended warranty. if i am told this is normal then i guess i am no longer an Orange player and the amp shopping continues
As I'm sure you've seen I've had some bad noise problems with my small orange ended up being failed valves however it did go back and I have just received a new one.
Might be worth going to a store that stocks Orange and trying one of their Rockerverbs to see if the same thing happens! How old is it and has it always done it?
the amp is about a year old, give or take 2 months, and has always made a lot of noise.stuart_tate41 wrote:As I'm sure you've seen I've had some bad noise problems with my small orange ended up being failed valves however it did go back and I have just received a new one.
unfortunately due to a tear in my shoulder my play time and ability to go out and do random things i want to get done are severely limited. i am leaving for Florida in a few days to visit family so i am hoping to attempt as much as i can before friday evening.
waiting to hear back from Orange technical support to hopefully get some more insight to what's going on
...looks like it is going to Orange USA to have it looked at, not just by an authorized dealer
Good. They tend to take any customer problems seriously. I suspect you may be able to stay an Orange player. Lots of noise with Oranges isn't normal!
Sounds like it's going to be sorted, good luck!
Yeh, I will be sending it out tomorrow...
While very unusual for Orange's reputation, ownership of this amp has been less than ideal. But! On the plus side, it's still a better experience than owning my Hughes and Kettner Triamp MK2 Alex Lifeson, that was a disaster. Great sounding amp but both of mine had issues. Even though I buy new I apparently have some bad luck!
Thanks for all the responses!
Users browsing this forum: No registered users and 81 guests
