Posted: Sat Aug 02, 2003 11:19 pm
by TXSPOILER
Has anyone replaced their rectifier tube in an AC30 with the Groovetubes solid state rectifier.They claim it makes an amp louder and have a tighter sound
Edited by - TXSPOILER on 03 Aug 2003 05:21:58
Posted: Sun Aug 03, 2003 5:25 am
by TXSPOILER
Sorry about the all caps post
Posted: Tue Aug 05, 2003 12:59 am
by justin
I don't think anybody knows if this is OK. I think the AD30 is too new of a model to have any kind of concensus about the viability of the amp with a SS rectifier. Since the GZ34 is the "hardest" (most SS-like) rectifier tube, it's voltage drop should be relatively close to a SS rectifier.
I asked around to see how I could find out for myself if the amp will take the SS rectifier. I've receiveed one reply so far from Aiken amps.
Here's what you do:
You need to measure the supply voltage and see if it's at least 40-50V below the voltage ratings of the filter caps. For example, if the supply voltage is 400V, and the filter caps are rated for 450V, things should be OK.
Posted: Thu Aug 07, 2003 8:21 pm
by Davis
Aspen Pittman, author of The Tube Amp book, recommends replacing the rectifier tube with "their" solid state version claiming just what you have mentioned. But think for a moment.....why did the guys at Orange not think of this, and other vintage & boutique amp builders as well? Hmmmmm....perhaps its because of the way a rectifier tube gives you that "sag" and response when you pluck a string or play a chord. Of course the rectifier tube has no effect on overall tone, but it IS there to add to the unique "feel" that you get from a class A amp.
I thought about replacing my tube when I read Aspen's book, but went out to my studio, plugged into my Orange...played...and decided against it.
Posted: Thu Aug 07, 2003 11:05 pm
by justin
Davis,
I'm driving a 4x12 cab with the rather ineffient Celestion Greenbacks in it. That speaker's breakup in conjunction with the 30 watt AD30HTC makes for a combo that's loud, but almost not loud enough. I actually wanted to try the SS recto for its intened purpose - to gain headroom. I've been meanig to get a good tube amp book. Do you recommend Aspen Pittman's? Is that THE one to get?
I'm not sure if your questions were rhetorical or not, but I have to add...
<i>"Hmmmmm....perhaps its because of the way a rectifier tube gives you that "sag" and response when you pluck a string or play a chord. Of course the rectifier tube has no effect on overall tone, but it IS there to add to the unique "feel" that you get from a class A amp."</i>
- "class A" and "sag" are completely independent of each other. You can have each of those characteristics in an amp in any combination.
<i>"But think for a moment.....why did the guys at Orange not think of this, and other vintage & boutique amp builders as well?"</i>
- I'm no history expert, but I think the guys who made the amps we now call "vintage" had no real choice for their rectification needs. Tubes were all they had to work with. I think most boutique amp builders add their own thing (or make a clone) to those old designs. It's tradition, and the amps sound good.
