Question about cr120h and ohms
I just ordered the cr120h head and realized that one of my marshall cabs is only mono at 8 ohms. The orange head doesn't let you choose it just says 16 ohm, however in parenthesis it says 8 ohm minimum. So even though there's not a switch will I be able to use the marshall cab or no? Any help would be greatly appreciated!
Re: Question about cr120h and ohms
You can either connect two 16-ohm cabs or one 8-ohm cab to the CR120H. The reason there is no impedance selector on the head is that solid-state amps do not require impedance matching. Just don't go below the 8-ohm minimum.
So am I not able to plug in one 16 ohm cab??Randy Bass wrote:You can either connect two 16-ohm cabs or one 8-ohm cab to the CR120H. The reason there is no impedance selector on the head is that solid-state amps do not require impedance matching. Just don't go below the 8-ohm minimum.
I'm guessing you haven't downloaded or read the manual. It's here:Avaryen wrote:So am I not able to plug in one 16 ohm cab??Randy Bass wrote:You can either connect two 16-ohm cabs or one 8-ohm cab to the CR120H. The reason there is no impedance selector on the head is that solid-state amps do not require impedance matching. Just don't go below the 8-ohm minimum.
https://www.orangeamps.com/wp-content/u ... l-V1.2.pdf" onclick="window.open(this.href);return false;
It states:
CR120H
Make sure the correct speaker load is connected
Do not connect a speaker load which is less than 8 Ohms:
1 x 16 Ohm Cabinet –connect to either speaker output
1 x 8 Ohm Cabinet - connect to either speaker output
2 x 16 Ohm Cabinets – Connect to both speaker outputs
Thanks so muchbclaire wrote:I'm guessing you haven't downloaded or read the manual. It's here:Avaryen wrote:So am I not able to plug in one 16 ohm cab??Randy Bass wrote:You can either connect two 16-ohm cabs or one 8-ohm cab to the CR120H. The reason there is no impedance selector on the head is that solid-state amps do not require impedance matching. Just don't go below the 8-ohm minimum.
It states:
CR120H
I'm actually still waiting to receive the head
I suppose it would have been clearer to say "...up to two 16-ohm cabs".
Could you connect both 16 Ohm outputs on the CR120H into both 16 Ohm inputs of the PPC412 HP8 400w Stereo Cab?
Why would you do that?DigiCol wrote:Could you connect both 16 Ohm outputs on the CR120H into both 16 Ohm inputs of the PPC412 HP8 400w Stereo Cab?
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
It's a stereo cab that runs at 200w per side at 16 Ohm's or 400w @ 8 Ohm's when connected in mono? So was just wondering what the best configuration was with a CR120H head as it has 2x16 Ohm outputs capable of running 2 separate 16 Ohm Cabs.Bensnake wrote: Why would you do that?
The amp sees an 8ohms load either way. The CR120 is a solid state amp that lacks output transformer. It doesn't behave like a tube amp. Se Randy's answer above and mine in your own thread.DigiCol wrote:It's a stereo cab that runs at 200w per side at 16 Ohm's or 400w @ 8 Ohm's when connected in mono? So was just wondering what the best configuration was with a CR120H head as it has 2x16 Ohm outputs capable of running 2 separate 16 Ohm Cabs.Bensnake wrote: Why would you do that?
2 x PPC412
Bax B. | Amp D.
Vox AC30C2X + V212C
Thanks manBensnake wrote:The amp sees an 8ohms load either way. The CR120 is a solid state amp that lacks output transformer. It doesn't behave like a tube amp. Se Randy's answer above and mine in your own thread.DigiCol wrote:It's a stereo cab that runs at 200w per side at 16 Ohm's or 400w @ 8 Ohm's when connected in mono? So was just wondering what the best configuration was with a CR120H head as it has 2x16 Ohm outputs capable of running 2 separate 16 Ohm Cabs.Bensnake wrote: Why would you do that?
Users browsing this forum: No registered users and 24 guests
