Oragne TH30 Bias
Oragne TH30 Bias
Does this amp need to be biased if I replace the tubes? This is a Orange TH30 amp...
Orange TH100
Mesa Dual Rec Multi Watt
Mesa Royal Atlantic
Mesa Cabs
Gibson Guitars
Taylor Guitars
Maxon OD 808
Mesa Royal Atlantic
Mesa Cabs
Gibson Guitars
Taylor Guitars
Maxon OD 808
Re: Oragne TH30 Bias
I believe it is cathode biased which means there is no bias adjustment needed.Legend wrote:Does this amp need to be biased if I replace the tubes? This is a Orange TH30 amp...
That is so. Doesn't mean that ALL valves will be run in the correct range, but all with fairly normal current ratings will.
Thing to do is just to specify which amp they are for when ordering valves from a good supplier and they should supply suitable ones. Then you don't need to worry about a bias check.
Users browsing this forum: No registered users and 19 guests
