Shutdown
Meole
Post by Meole » Thu May 30, 2002 12:46 pm
After prolonged amp use, how do you shut your amp down?
Do you just turn the thing off? Do you put it on standby and let it cool down before turning off?
Also, when using the amp for the day, do you leave it on if you plan on using it in a little while,
or do you turn it on and off each time? What is your longest usage time?
Post by bclaire » Thu May 30, 2002 8:06 pm
I shut the whole thing off and have never had a problem with any amp and I've been doing that for 30 years..... besides, a standby switch is a new development for Orange anyway! Billy
davidofdavidom
Post by davidofdavidom » Thu May 30, 2002 10:49 pm
You are supposed to switch straight off. And Oranges have only had stand bys for couple of years, and with SS rectified, Im unsure why???
reggieisadork
Post by reggieisadork » Wed Nov 20, 2002 11:03 pm
Flip it to standby for a few seconds before shutting down. This will increase the life of your tubes. Just because the standby switch is new doesn't mean it's not a good idea to use it. God bless,
~Reggie
~Reggie
Davis
Post by Davis » Tue Nov 26, 2002 9:06 pm
You should ALWAYS use the standby switch before shutting down your amp....waiting approx. 30 seconds before hitting the "off" switch. This will lengthen tube life (and tubes ain't cheap) as well as allow voltages inside the amp to settle down properly.
I own several Mesa/Boogie Amps and they alway "firmly" recommend this proceedure.
It makes sense.
Tibor
Orange Hero
Post by Tibor » Tue Dec 10, 2002 6:30 pm
BUT??? What should i do? I use an Overdrive120....WITHOUT ANY Standby Switch! And i dont want to modify my amp! Turning Volume down is useless as far as i know!....?????
Why is an ORANGE, orange? If it would be Green it would be an apple....
Post by bclaire » Tue Dec 10, 2002 10:56 pm
Just shut the thing off! I always hear a lot of talk about extending tube life but no one can really prove that.... it's just people's perception. Who knows if you're really getting an extra day or two out of your tubes? I have never, ever, had a problem with shutting an amp off. I always just click both switches on a standby switch-equipped amp or just the power switch on my older Oranges...
