Hi,
The output transformer on my Rockerverb 50 head brings in a huge amount of hum when I turn the reverb up. I'm pretty sure it's the output transformer because when I move the input side of the tank closer to it, it gets really loud!
Anyone had any similar problems? Could I use some shielding?
Thanks....
Transformer hum increases with reverb
Re: Transformer hum increases with reverb
You modified your tank with Blues Junior parts if I recall correctly ? Chances are the input impedance of the tank is no longer correct. Reverb tanks are not expensive, I would suggest you buy a replacement and make sure the model codes are correct so that the input and output impedance is correct. Accutronics tanks are nice, I don't like the Ruby tanks that Orange uses in some models, they sound more like hall reverbs.
I think you might be right since the input impedance is different on the blues junior tank. The only problem is that the accutronics tank that came with my RK50 is now discontinued. It's model code is 8AB2C1B. I'm in Ireland so I can only really order from the UK to avoid paying import taxes! There's a tank with model code 9AB2C1B available on a UK site. That should work right? I would just have to use my original springs and housing since they are different in physical size, but the impedance etc is the same.sizzlingbadger wrote:You modified your tank with Blues Junior parts if I recall correctly ? Chances are the input impedance of the tank is no longer correct. Reverb tanks are not expensive, I would suggest you buy a replacement and make sure the model codes are correct so that the input and output impedance is correct.
It could be faulty, maybe a grounding issue in the tank but then again it's really hard to know. I found the tank replacement here at allparts.uk.comDannyboy wrote: Could my reverb tank be faulty? My tank is a 3AB2C1B which is the same as yours (I think the first number is just the manufacturers/size reference) and I've had trouble finding a replacement. What site did you find that replacement tank?
http://www.allparts.uk.com/online-shop/ ... -5374.html" onclick="window.open(this.href);return false;
That tank has 6 springs instead of 3 and is almost twice as long. You could try and transplant the parts you need but they are pretty delicate.DRennick wrote: I think you might be right since the input impedance is different on the blues junior tank. The only problem is that the accutronics tank that came with my RK50 is now discontinued. It's model code is 8AB2C1B. I'm in Ireland so I can only really order from the UK to avoid paying import taxes! There's a tank with model code 9AB2C1B available on a UK site. That should work right? I would just have to use my original springs and housing since they are different in physical size, but the impedance etc is the same.
You can still get the 8AB2A1B model which is the same as your except the input is connected to ground. (the outer ring on the RCA connector is connected to the chassis) It may be easier to modify that by removing the wire or changing the plug/socket depending on how the ground connection is made.
I would give Orange UK a ring to and see if they can help.
From what the website says it only has 3 springs. I may give Orange UK a call though to see what they say.sizzlingbadger wrote: That tank has 6 springs instead of 3 and is almost twice as long.
I was looking at the type 9 reverb tanks here http://www.accutronicsreverb.com/" onclick="window.open(this.href);return false;
Must give it a try, thanks DannyBoy!
I ordered a new reverb tank - model 8AB2A1B. All the impedance matches etc but the input on this tank is grounded apparently so I think I need to do a mod? I can't see any extra wires though on the new tank. Also the input/output sockets are different, they are the newer rca jacks so my old cables don't fully go in to them.
What to do??
What to do??
Users browsing this forum: No registered users and 97 guests
