jontheid wrote:I think it is a typo though, most EL84 based amps do use cathode bias.
I don't know. Not sure either way. Though we all know (and mostly love) the various usually more or less Vox based 4xEL84 cathode biased amps, there are actually plenty of fixed biased 4 x EL84 amps too. And frankly if these come from the factory biased on the cool side (as most do!) then most of the time you can also pretty safely slot in any reasonably matched modern EL84s and they will be run well within the normal bias range. (I know, no guarantees, but...)
My old tech John is very keen on Mesa amps and has worked on many many of them. Most Mesas (whatever the valve type) are fixed bias, and all of
those are non adjustable ie no adjustmant pot. However John has NEVER actually had to alter the bias in one when fitting any good set of valves:
http://www.thegearpage.net/board/showpo ... ostcount=3" onclick="window.open(this.href);return false;
Ditto with the Peavey classic 30:
http://www.thegearpage.net/board/showpo ... stcount=25" onclick="window.open(this.href);return false;
It may be that the Eurotubes quote is kind of lumping all 'Vox type' EL84 amps into one and comparing that with all the various different non cathode biased EL84 types they have to supply for. In which case ironically I can just about understand what they are saying. Though it is important to have the biasing in the right range, if these fixed biased amps are biased fairly conservatively (coolish) from the factory, then in fact they will run almost all valves just fine.
(Sorry if that thought complicates things even more. It may also just have been a typo!!!)
