I own a stompbox modeler which I use for stuff like delays and reverbs and other effects.
As I don't fancy tapdancing, I was running into trouble when I wanted to switch off the effects and use the dirty channel.
After a long search I ended up buying a Nobels MS-4 which is simply working great along with my RV50.
This is the way it works:
The effectboard sends program changes thru the midi out.
The Nobels recieves these messages and you can store that message and tell it which channel it should switch the amp to.
This should also work on every midi floorboard or effects unit which send program changes or is able to send midi commands.
And it should work on every Orange amp which is footswitch compatible.
Just thought there might be some others who have the same problem I had.
External channel switching
