Footswitch LED and Dual Terror
Anyway to get the the light to go on when you use the fat channel not when you use the Tiny terror channel? I'd imagine you'd have to change the wiring?
Re: Footswitch LED and Dual Terror
Sorry, but I don't think it's possible without complicated surgery.
you could add a 9v battery and rewire the led so that the ground to the led makes connection when the switch is deactivated, possibly. I recently built a channel selector for my ad140 and noticed that it was noisy when the channel was engaged. I assume this is because i left the LED out and the orange was built with the voltage drop of the LED in consideration, so you would probably want to keep the original and add a new one. ultimately, it would be more work than it's worth, as you know that when the light is off, your on the fat channel, and I'm sure you can get used to that idea.
