Zero-Loss FX Loop Kit
http://metroamp.com/store/index.php?mai ... cts_id=499" onclick="window.open(this.href);return false;
is there a schematic available for the rocker 30 so i could figure it out?
also, are there any gut-shots of the rocker-30?
thanks in advance
-JWM
Would a Metro-Amp Zero-Loss FX Loop Kit work on a rocker-30?
Re: Would a Metro-Amp Zero-Loss FX Loop Kit work on a rocker-30?
Assuming that the voltages check out and you have the physical space to accommodate the pcb, I think that it would work. However, if you haven't the experience or means to take this measurements, I would say you should take your amp to a tech and ask him if it would work and how much he would charge to install it.
I want to do the same thing to my dual terror how did this work out for you ?
Users browsing this forum: No registered users and 220 guests
