Trouble with my Tiny Terror!
Hey..
I recently bought a Tiny Terror, used, but not too old.. I got home, plugged it into my 1966b cab and cranked the volume up. When I do, it starts like... howling, a kinda high frequent piercing sound. This starts if I've got my volume knob at around 12 if my gain is all turned up, or when the gain knob is at 14 when my volume is all turned up... I've tried with several guitars, other cabs, a lot of cables but nothing seem to help. The sound is like louder than what I play so it's not just like a background fuzz..
Anyway, the tiny terror aint a too loud amp, and this screech makes me just being able to use 50-70% of it's full volume....
Anyone ever heard of this before?
I'd be deeply greatfull for any solutions
Re: Trouble with my Tiny Terror!
the TT is totally a loud amp! did you check the tubes, i.e. replace/swap any of them out?
--Nick
Nah, I like tapped them with a pencil, someone said that if there was a loud noise comming out of the cab the tubes were microphonic.. There wasn't though, but I think I'll replace them anyway. ;p
hmmmm....i think that might be as far my expertise go...which is kinda pathetic. i've heard of ths problem before, but i can't remember where on here.
--Nick
Any time you buy a used tube amp you gotta expect that the tubes could be close to shot. Retube it, and see how it is. Chances are, that's the source of your problem.
Sounds like a plan.. Uhm, should I change all the tubes, or just the ones in the preamp?
Hi!Remy wrote:Hey..
Maybe bad guitar\cabinet cable. Try to overwind it when it is connected to amp+guitar+cab.
Yeah, but i've tried like... 3 diffrent cab cables and like 5 diffrent guitarcables, and even another cab, I really think it's got to be the TT
do anything about the tubes yet? actually...wrong question - do anything that helped your issue yet? any progress?
--Nick
Not yet... However, yesterday I noticed that there was some loose parts inside the amp, so I cracked it open, turns out it was just 3 screws that should have been holding the main PCB on place, but there was like 3 others holding it in place, however I put them right back in their places... I didn't find anything else odd inside the amp though. But again, I'm not that good with this whole amp technology.. But there was no diffrence when I had put the screws back in place with the sound, but now there's nothing loose inside the amp!
I think I might be dealing with a microphonic power tube.
Watch these:
http://www.youtube.com/watch?v=QM2qWZYbInI" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=NAF42EwLzks" onclick="window.open(this.href);return false;
Watch these:
David
Yeah, I was by the store today and ordered 2 12Ax7 preamp tubes, they didn't have it in store.. Anyway, I've never changed a tube before, any particular stuf to think about?
1. They pull straight out so don't twist them too much and they don't screw in like a light bulb.
2. Pay attention to the pin placement. The tubes can only go in one way and on the 12ax7s there is a noticeable gap between two of the pins. Just match that up with the gap in the tube socket. Really easy stuff.
And if you already knew all of this stuff, just skip what I wrote.
Jake
did screwing the pcb back into place change anything? stupid question, maybe...but i dunno that much about electronic theory and maybe the PCB was getting to close something, or maybe...something....lol...
andy? neil?
as for the tube swap - i find my tung sol a lot tighter in the socket than the jj, not sure why. but it take a fair amount of wiggling. i heard you're not really supposed to wiggle, but i can't get'em out otherwise...i'd be open to suggestions.
andy? neil?
--Nick
This sounds like my Marshall when the tubes were "finito".Remy wrote:Hey..
Users browsing this forum: No registered users and 142 guests
