Hi Everyone, I think i need to replace my reverb tank in my rockerverb 50 combo. Wdoes anyone know what i can use to replace it? Looks a simple job. my reverb is intermittant but works again when i take fiddle with the phono plugs. Its not the plugs or cable or amp (btw)
I was wondering if anyone knows if i could put a different tank in? just to mod it and be different?
Also like many people things end up in the back of the combo from gigging, bits of drumkit etc?? so i would like to protect the tank somehow? other combos have the reverb tank in a bag of sorts is this a good idea?
Any help appreciated.
Ohon another not i've just re-valved it with Harma drive tested STR's replacing the old JJ's WOW i will post about them l8r!
rockerverb reverb tank
http://www.tubesandmore.com/scripts/fox ... =P-RBAG-17
this is the bag i was talking about. Reckon i will just haul out the tank after tomorrows gig and geth the serial. Its def the tank as when the reverb stops working i have to take out the tank, unplug everything and plug it back in to get it working again. I've had a tech check the amp part and he says its fine.
I think i'll give orange a call and see if they can supply me with one. will keep u posted
Rocker 30, RV 50c, VOX AC15, 76 Les Paul, Eric Johnson SB strat, 57 strat, vox clyde mccoy, ehx small stone, ehx nano LB-1, Boss DD-6 + TR-3.
Users browsing this forum: No registered users and 90 guests
