I originally posted this to the Community forum, but maybe it should be here. So I am reposting in the Technical forum.
I'm asking for help from anyone who has experience with the early (2004) Rockerverb 50.
I got a used 2004 Rockerverb 50 on ebay. It had the following: Broken reverb tank wires (now fixed), unshielded reverb cable, and Dagnall transformers. I never use reverb, so does that mean I don't need a shielded cable? I have replaced the Dagnall OT and choke with MM, this made a noticable and welcome improvement! The PT seems to be functioning fine, however, would putting a Mercury Magnetics PT help anything? Lastly, I've heard that the early RV50s sometimes suffered from cold solder joints. How can I tell if I have this problem?
Thanks in advance to anyone who can help.
Early (2004) Rockerverb 50 questions
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RedOrange</i>
<br />I never use reverb, so does that mean I don't need a shielded cable?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If you do use reverb and you find the reverb to be unnecessarily noisy, switching to shielded cables for the reverb connections is a wise first-thing to check on.
<br />I have replaced the Dagnall OT and choke with MM, this made a noticable and welcome improvement! The PT seems to be functioning fine, however, would putting a Mercury Magnetics PT help anything?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Putting in a new PT would do very little, if anything to your amp's functionability. As far as power transformers: if it meets spec's and ain't broke, it's a waste of time and money to replace.
<br />Lastly, I've heard that the early RV50s sometimes suffered from cold solder joints. How can I tell if I have this problem?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
If a solder joint is cold and somehow becomes an intermittent connection, you'll notice some intermittent problems with your amp (no sound, high squeels, or buzzes) - so until that happens, I don't think you'll need to worry.
'74 Orange OR120 w/Contemporary Avatar 4x12 V30s
'04 Orange AD30 w/Traditional Avatar 2x12 w/G12H30s
http://www.jooniorstudios.com/
http://www.youtube.com/user/chrismathewsjr/
<br />Thanks! The amp sounds fantastic, so I'm ready to rock.
Welcome here any time and welcome to the club!
Users browsing this forum: No registered users and 79 guests
