Rocker 30 Problem! help!
d.vid
Post by d.vid » Mon Mar 24, 2008 9:25 pm
so i was playing my R30 the other day pretty loud. and then all of the sudden, the volume got so quiet on both channels. now, i cant hear either channel of the amp at all unless i turn it way up (passed 12'o'clock). if i do that, i can hear it. but it is very, very quiet.
I dont know what the problem is! i dont think its the power tubes, they look like they are fine. they're glowing a little blue/violet, but nothing out of the ordinary. i dont think its the preamp tubes either be cause i can still hear the amp a little if i turn it way up. my Rocker 30 is only 4 months old.. so i would think all the tubes would be fine. but im not sure..
can any of you help?! please! :?:
thanks in advance! :D
-David
scissorlock
Post by scissorlock » Mon Mar 24, 2008 10:00 pm
the exact same problem with my thunderverb. i took it to a tech. it was a power tube issue for me.
just because they're glowing doesn't mean they're fine.
Simon Wicks
Post by Simon Wicks » Mon Mar 24, 2008 10:43 pm
Yeah, sounds like a power tube issue. One of the pait has probably shorted.
Andy H.
Post by Andy H. » Tue Mar 25, 2008 6:24 am
+1.
Or possibly the last of the preamp valves, the 'phase inverter', as both channels go via that to the power amp stage. That is the furthest away of the three from the guitar input socket.
Try replacing that first if you have a spare preamp valve handy. (And if you haven't, why not...? ;))
d.vid
Post by d.vid » Tue Mar 25, 2008 5:39 pm
I just tried replacing the V3 preamp valve.. didnt fix it.
ill take it into the shop i got it from and throw a new pair of EL34's in it and see if that fixes it.
thanks guys for the suggestions!
-David
blackcloud45
Post by blackcloud45 » Tue Mar 25, 2008 8:38 pm
Save yourself the diagnostic / labor fee and swap 'em yourself. The Rocker 30 doesn't have to be biased. Just get the 6CA7 (or EL34 in your case) replacement tubes, plug 'em in and go! If that doesn't work, then take it in...
d.vid
Post by d.vid » Thu Mar 27, 2008 7:29 pm
ok, So i just got two JJ Kt77s and put them in.. and it didnt solve my problem!! :evil:ARGG!
I dont know what it could be.. the amp isnt even 4 months old! HELP! what should i do? when i bout it new, i didnt get any warranty papers or anything.. so i dont know what i can do. ah.
-David
