der Gerrit
Post
by der Gerrit » Sun Dec 15, 2002 8:07 pm
Hi! I have a problem with my Orange AD30HTC!
Sometimes the Channel Two is much more quite than Channel One.
If I "shake" it a little bit it works normally again.
Is it possible that maybe the tubes aren't really connected or something like that?
Another question:
Is it normal that at Channel One the Sound gets extra loud if I turn it up from 10 to 11(Master)? It's like a step. Should that also happen at Channel Two?
Thank you very much for helping me!
Gonna take my chance,
gonna rock and dance!
Meole
Post
by Meole » Mon Dec 16, 2002 2:47 am
Shaking it is not good. Same with dropping it!!
der Gerrit
Post
by der Gerrit » Tue Jan 07, 2003 4:05 pm
Allright. Now I know what was damaged at my amplifier.
The tube-socket had a problem with one connection, so that sometimes the amp wasn't able to use one or some tubes...
pgmlml
Post
by pgmlml » Sun Jan 12, 2003 11:11 pm
By the way you describe it, seems that one side of the PI has a bad contact... I had a similar problem!
Open your amp, get a wood stick, and with the amp turned ON, hit each conection, till you find your bad joint. Then Solder it agin! That's what i did!
Users browsing this forum: No registered users and 89 guests
