After reading various internet rumours, and not being much of a technician i was wondering if my amp is "plugged in" wrongly.
There is a little coin adjustable Ohm selector which has 4/8/16 on it, its currently on 8. Both the speakers are plugged into output one of two and they are 8 Ohm celestion vintage 30s.
Is it all in the right place or do i need to change anything pronto?
Any information would be wonderfull.
Cheers.
Orange 0TR 80 impedance
Unless you only have 2 positions marked on your selector, or there's a sticker over the original chassis lettering to relabel the positions...
Run it on 4 ohms into that cab.
Orange designed the '80W'ers with an inherent impedence mismatch because they used the same transformers as the '120W'ers.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>Both the speakers are plugged into output one of two and they are 8 Ohm celestion vintage 30s.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>Just to clarify, is this a 2 x 12 cab / combo with two 8 ohm speakers inside, or is the whole cab / combo rated at 8 ohms?
If it's the whole cab, then I believe 5/8/10 is right, run on the 4 ohms setting.
If not, we'd need to know just how the speakers are wired up - could total 4 ohms (but probably won't!), or 16 ohms (in which case you'd have to run it on the 8 ohms setting due to that daft 'mismatch').
Users browsing this forum: No registered users and 79 guests
