My AD15 doesn't power up. The rectifier glows, but the power light doesn't come on and the other tubes don't glow at all.
I checked the fuses, which seem OK, changed out the rectifier and power tubes, but no effect.
I've seen similar posts, but reading through the past responses, didn't see any answers. Thanks for any advice.
Dead AD15
Thanks for the reply. It ended up coming back to life, and I'm not sure why. It has been sitting in my house the whole time, so rough handling shouldn't be the issue.
I tried changing out all the tubes, messing with all the connections, checking fuses, etc. It just came back on! I have the tubes in it that were in place before this happened, and it's working fine.
I still can't explain it, but I'm happy to have it back. Maybe one of the tubes was loose, but I checked for this first...
This ended up happening again so I took the amp to a tech (Erik Miller of Euthymia in Alalmeda, CA). He diagnosed the problem as a loose connection in the 6v heater circuit (right next to the base of the rectifier tube socket). It's fixed!
Just thought this info might be useful if anyone else has a similar problem.
It seems kind of strange that the pilot light would not come on if the heater circuit had a loose connection.
'74 Orange OR120 w/Contemporary Avatar 4x12 V30s
'04 Orange AD30 w/Traditional Avatar 2x12 w/G12H30s
http://www.jooniorstudios.com/
http://www.youtube.com/user/chrismathewsjr/
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by skrzyp</i>
<br />Erik showed me the issue, and it turns out that at that location (next to the rectifier) in the AD15, a broken connection cuts off power in the 6v circuit all the way down the line after the rectifier (including the power light).
Well, problem solved then.
Re: Dead AD15
I keep having the same problem. Won't power up, only rectifier lights up and no power light. Had it fixed twice (the problem was a solder joint) and now it broke for a third time. Any advice on this? What does my tech need to do to permanently fix this issue??
Re: Dead AD15
I thought this sounded like a heater wire issue!
To get the problem permanently fixed you need the tech to hard wire ALL the heater connections.
Cheers,
Jon
Cheers,
Jon
Users browsing this forum: No registered users and 212 guests
