Tube problems?
I've been noticing lately that the clean channel on my AD-140 is distorting slightly, even on the lowest gain settings. I read somewhere that it could be a problem in the preamp tubes, and to change them out. I decided to double check the tubes, so I warmed up my amp for like 5-7 minutes, and I noticed that the power tube furthest right was not glowing and was cold. The rest were at least lukewarm and orange. This might be obvious, but should I change it out, or is that normal? Any help would be greatly appreciated.
"not glowing and was cold" means its no longer a power tube
Basically that says that it is either dead! or not in the tube socket properly (more than likely dead)
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>least lukewarm and orange<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
I don’t know about the AD140 (i have the AD30) but i haven’t touched the tubes after 5-7 minutes because i know they a so f'in hot, you can feel the heat from a mile away.
Them being “Luke warmâ€
Dave
If your amp is on standby whilst it's warming up, are the tubes always roasting? But ditto to the other comment... if it's on full power, then you should be able to feel it if you wave a hand over it.
Well...maybe "lukewarm" was a little underexaggeration. I warmed it up in standby for about 10 minutes, and they were hot. But still the one was cold. Is there a certain way the tube should be sitting in the socket? Or can it go in any way? One other question, if it is dead (I'm pretty sure it is) can I just change the one, or should I change them all?
Right, if you haven’t changed the tubes, then its not biasing that’s the problem.
http://www.theallens.theallens.com/Powerampreplace.htm
The tube should be vertical (if you haven’t taken it out then it will be in right)
Everything’s pointing to a dead valve. You "can" only replace one. But its highly advisable to either replace in a pair or in a quad (replace 2 or 4) And when you do replace them you will <b>Need</b> to take it to a tech to be biased.
I’m still surprised that you only class the valves as "hot", but maybe that’s how AD140 are.
Dave
Dave
Dave
Sounds very like a dead tube to me too. There is only one way the tubes go in - the pins only seat when properly aligned.
That being the case, as Dave says I wouldn't just change the one. At the very least change the other of the pair. A pair will be the inner two, or the outer two, not the left two / right two.
And yes, get a technician to check the bias with the new tubes. This is just part of the necessary mantainence with a valve amp, although 6 months is not a very impressive lifespan for a tube, unless it has been worked hard. If you pay extra for good quality matched valves they would tend to last much longer then that, but as with lightbulbs it's impossible to predict just when they'll fail.
If you get a new set of matched valves, make sure they are 'dual' matched... better option than single matched.
Anyone know what valves Orange use as stock? Or what valves those Orange branded ones sold on the site are?
Yikes...
I'd bring it back to the dealer where you bought the amp and see what they can do for you. I'd want to know for sure that the tube is getting juice- and not just burned out. Tubes start to wear out from the moment you start using them but that's suspicious for a 6 month old amp!
Billy
Edited by - bclaire on 26 Jul 2004 00:20:12
Billy
Do I really need to get it biased? I read this from an earlier post.
http://www.orange-amps.com/forum/topic.asp?TOPIC_ID=363
quote:
Hey people,
All our class A amps are self biasing - (AD15's and AD30's). Feel free to change the brand of tubes and
experiment as much as you want!
<b>AD140HTC's are pretty much happy with all brands of EL34's that we have tried with the factory bias setting so
again you shouldn't have any problems swapping out tubes.</b>
AD200B's do need some adjustments for different tubes. Either take your amp to your local amp guy or call your
nearest Orange office for advice.
Hope this helps!!!!
Admin - Orange Amplifiers
I really want to take care of my amp, but I don't have too much money right now. In your opinion, should I take it in anyways? And about how much would it cost to get it biased?
quote:
Hey people,
Hope this helps!!!!
quote:
Hey people,
Hope this helps!!!!
the ad15 and ad30 are class A cathode biased and need no biasing. the ad140 is class A/B and does. No what someone tells me, I always get my class A/B amps rebiased.
quote:
Hey people,
Hope this helps!!!!
Users browsing this forum: Google [Bot] and 249 guests
