bp2fl
Post
by bp2fl » Fri Aug 23, 2002 3:29 pm
I have a 140tc head and when i started using a footswitch sometimes when going from channel one to channel two, it would mute the amp instead of switch it. I thought it was a problem with the footswitch, so I took it back. Now it's starting to do it occasionally when i'm MANUALLY switching between channels. What's the deal? Any ideas?
Thanks!
Brian
Post
by bclaire » Wed Aug 28, 2002 12:24 pm
sounds like the wrong type of footswitch- if it's a momentary one, then that's your problem. You need an on-off type. Billy
Just Blaze
Post
by Just Blaze » Sat Aug 31, 2002 9:18 am
definatlly make sure that one or more of the pre amp tubes are not loose. my AD30TC used to do that before i checked them.
Users browsing this forum: No registered users and 221 guests
