Hi all!
Here is Hong Kong.I just got my AD140HTC and PPC412.But i found some problems when using them.
When I plug my guitar in and play, I just got sound from the top left and bottom left speakers instead of all four...
what is the problem?
And i found that there are two input jacks behind my PPC412..I just connect one of them to the 16ohm output of the AD140HTC...is it the reason ?
PPC412 Problems
Hi Hong Kong. This is Stefan.
I've received my Ad30htc and ppc412 yesterday. And I was a little bit confused, cause there are two inputs on the back of the cabinet, and no one is marked with impedance or which is for mono.
Tomorrow I'll try if I've got the same prob as you.
Maybe one input is for two loudspeakers and you have to put two cables from the two 8 Ohm outputs to the inputs.
But i'll try.
Maybe you find the answer, then, please write back.
But i'll try.
Users browsing this forum: No registered users and 195 guests
