Is the hand wired TT still available?
Gut pics here:
http://forum.orangeamps.com/viewtopic.p ... ed#p593535" onclick="window.open(this.href);return false;
Different types of amp design & construction
Re: Different types of amp design & construction
Only second hand. I had my hands on one last year. Wish I've bought it...a.hun wrote:Is the hand wired TT still available?
Gut pics here:
Here's a Terror shoot out vid:
http://www.youtube.com/watch?v=4wNOK-JoXHc" onclick="window.open(this.href);return false;
2 x PPC412
Bax B. | Amp D.
Marshall 1959 HW + 1936V
Vox AC30C2X + V212C
Jim Root #4
Cornford RK100 and MK50
Cornford and Trace Elliot cabs
Gibson, Gordon Smith, Musicman, Fender guitars
excellent post sir
a.hun wrote:PCB. The green bit with lots of white printing and copper lines is your printed circuit board.
In fact apart from the rare modern Custom Shop amps Oranges have ALWAYS been PCB construction. Though they used to chassis mount the valves instead of mounting them on the PCB itself as is done these days. However if the board itself is strong enough (yes) and is properly reinforced with spacers (yes) than unless there are any heat related problems (not so far) there shouldn't be any real big reliability issues.![]()
Properly done PCB is just as reliable as any other build method, and is actually less likely to have noise issues due to random positioning of wiring, components etc. With PCB build everything is all laid out pretty much exactly the same from amp to amp. It is really just cheaply put together PCB electronics that give the technology a bad name. But a poorly built amp is poorly built even if that is all done PTP by hand!![]()
PTP is in no way inherently more reliable than PCB. See this thread HERE comparing old Marshalls and Hiwatts, in particular posts #15 and #22.
During the later 70s Marshall went to PCB construction, but the reliability didn't drop at all at with that change. It was only years later (around 1990) when that happened, when they introduced a new range (JCM900) which were built to a price instead of to their own traditional high standards. The 70s Marshall amps (both pre PCB and PCB built) being discussed on that thread, alongside '70s Hiwatts, vintage Oranges and just a few others were (and if well maintained still are!) about as reliable as any amps ever built.
Remember though, there is more in many modern amps to go wrong than with those simpler older amps. Have a look at the inside of my OR120. Ignoring the (non original) doubled up capacitors on the PCB there is a lot less happening inside there than in your RV, right?
Your amp (like my Rocker 30) is put together to a pretty decent standard. Not the worlds best quality, but no huge issues either IMO. (Use of press on spade connectors being by far my biggest complaint!) Well above average run of the mill build quality at any rate.
But... with more complicated circuitry like the more complex modern amps there will inevitably be more potential for things to go wrong. Thats just the way it is and the reason why a lot of us believe simplest is usually best. Even so the vast majority of all problems with good quality modern valve amps are with the valves themselves. Keep a couple of spare valves and fuses handy and you and your amp will be fine!
Happy?![]()
Very interesting info here
Orange Rockerverb 50 , Orange TH30 , Orange Or15 , Orange PPC412 , 2000 Gibson Les Paul Classic , 2013 Gibson Les Paul Traditional Pro II with Floyd Rose , 2010 Gibson SG Standard , 2009 Washburn N4 , 90s ESP Sunburst Tiger , 90s ESP Skull and snakes
Solid State awesomeness: CR120
We now can add the total hand-wired Shiny Terror/ 10th Anniversary Tiny Terror to the list, which distinguishes itself from the previous hand-wired TT by being hand-wired without a turret board.
But I thought the original hard-wired TT didn't use a turret board either?
Indeed!jontheid wrote:But I thought the original hard-wired TT didn't use a turret board either?
With the new one you are paying for 'shiny' - shiny costs!
Guys I am not an expert and a complete noob here just want to know your opinion on this amp manufacturer https://www.icrfq.com/brand/563 , would be very grateful for a review!
There is additionally another kind of development technique: PCB turret board. This is a blend of PCB follows turrets. This permits simple substitution of parts while holding the superb mechanical strength of PCBs. This was concocted and is only utilized by Matamp, who thought of the thought in the wake of fixing numerous Hiwatts taking note of the main issues were the wires connecting the turrets severing.
Friedman uses this toorutuja wrote: ↑Mon Mar 04, 2019 9:03 amThere is additionally another kind of development technique: PCB turret board. This is a blend of PCB follows turrets. This permits simple substitution of parts while holding the superb mechanical strength of PCBs. This was concocted and is only utilized by Matamp, who thought of the thought in the wake of fixing numerous Hiwatts taking note of the main issues were the wires connecting the turrets severing.
I get nervous when old posts are resurrected by a first timer...
