can you hook up an extra 4x12, 16 ohm cab in the 8 ohm output???
the 2x12s are 16 ohm?
ext speaker w/ ad30tc
Thanks! there is one - 16 ohm, and two - 8 ohm speaker outs. they are not designated to that ohmage? the lowest I assume is 4 since 2 x 8 = 4 ohms
2 x 16 = 8 ohms the combo is 16 ohms ? right? I hav'nt looked inside the amp yet? Thanks for the Info! what I am saying is should I plug the 2 -16 ohm cabs into the 2- 8 ohm outputs since it will be 8 ohms?
well, if it is anything like the newer Marshall cabs, the 8 ohm inputs are stereo (1 speaker per input) and the 16 ohm mono (2 speakers per input).
As far as the resistance, it all depends if they are wired series or parallel, which I don't know. I would just follow what it says on the cab, unless you've changed the wiring/speakers.
Users browsing this forum: No registered users and 199 guests
